MallCrawlin.com Forums
Go Back   MallCrawlin.com Forums > Tech > Drivetrain
User Name
Password
Home Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Drivetrain Advanced technical discussion regarding ZJ and WJ drivetrains, including axle swaps, lockers, and any other crazy shit you can come up with!
Reply
Thread Tools
Old 04-17-2006, 02:38 PM   #1
EMTimZJ
EMTimZJ's Avatar
EMTimZJ will become famous soon enoughEMTimZJ will become famous soon enough
EB Dana 20 Twin Stick Modification (T-shift)
This write up covers the necessary internal modifications that can be done to an Early Bronco (EB) Dana 20 (D20) T-Shift transfer case.
Some Quick Facts:
Driver side drop
Cast Iron, all gear driven
2.46:1 low range (T-shift 1966-1972) 2.34:1 low range (J-shift 1973-1977)
Fixed yokes
Can be used in any mode in any gear range after modifications are complete
Rear wheel only high / low. 4x4 high / low. Front wheel only high / low.
NOTE: this is not the same Dana 20 found in CJ’s!
The J-shift case requires no internal modifications.
I had very few instructions so I ended up disassembling a little more than what was needed. So if you see some parts missing or removed that do not need to be, just keep that in mind.
Start by removing input gear, inspection plate, and tail cone. Drive the tail cone out from the inside out. Collect the 13 needle bearings!
There is a retaining tab that holds the idler gear shaft in place (center of transfer case). Remove tab, apply as much penetrating oil as possible and start driving out the pin. I used a 22mm socket on a 10” extension and a 4lbs hammer. After the first inch or so you will see the first set of needle bearings. When you can, start pulling them out with a magnet. There are two sets of 24 each (total of 48) so do not lose them!
Once the idler shaft is driven out enough you can remove the idler drive gear.
Now there is enough room to get at the set screws that connect the shift forks to the shift rails. The set screws are 3/16 hex.
The shift rail/fork for the rear is easy and very accessible.
Remove set screw (inside of case) and detent ball and spring (outside of case on either side of the shift rails) and you can slide the rear shift rail out the front.
Tip the case; knock on it with the hammer and one of the interlock pins will slide out the same hole as the detent ball and spring.
Illustration of the interlock pins and their location (labeled “rods” in the diagram).
Photo from classicbroncos.com
Same procedure for the front shift rail/fork. This set screw is a little tougher to get to but it is possible. Slide out shift rail and remove the second interlock pin.
Reinstall shift rails / set screws / and detent ball and springs.
Place intermediate thrust washers (brass looking), idler drive gear, and drive the idler shaft part way back in. Now you need to reinstall the 48 needle bearings.
**Before you put the idler drive gear in place, you must install the 3 needle bearing spacers inside the idler gear before driving the idler shaft in place.**
Brass Thrust washer in place. There is a notch in the case that matches up to a raised portion on the washer, it will only install correctly in one way.
2 removed interlock pin in top left, 2 brass thrust washers in center, three bearing spacers, 2 shift rails.
Picture I made to illustrate how the bearing spacers and needle bearings install inside the idler gear.
I used the same 22mm socket and extension to help the needle bearings from collapsing while I hammered the idler shaft back into position.
A diagram of all the T-shift parts and locations.
Photo from broncograveyard.com
Hope this helps anyone as they attempt to twin stick their EB Dana 20 T-shifts. I searched and searched and could not find any real write ups, so mallcrawlin has the only one so far!
-Tim
__________________
-94 ZJ-
EMTimZJ is offline   Reply With Quote
Old 04-17-2006, 03:15 PM   #2
Cue-Ball
The Oil Dude
MallCrawlin Vendor
Cue-Ball is a jewel in the roughCue-Ball is a jewel in the roughCue-Ball is a jewel in the roughCue-Ball is a jewel in the rough
Re: EB Dana 20 Twin Stick Modification (T-shift)
How is the strength of this case compared to a flipped D300??
__________________
Get all the latest information on Zach Yost at his NEW website HERE
Cue-Ball is offline   Reply With Quote
Old 04-17-2006, 04:34 PM   #3
EMTimZJ
EMTimZJ's Avatar
In stock form, a stock V8 and 35's is just fine. Once you go further, upgrade the stock 10 spline output to the 32 spline output. The weak point is the same as a stock Dana 300. Both are upgradeable to the 32 spline output that the Atlas uses. Just like the D300, the D20 is stronger than the 231.
-Tim
__________________
-94 ZJ-
Old 04-17-2006, 04:35 PM   #4
Cue-Ball
The Oil Dude
MallCrawlin Vendor
Is there 4:1 gears avaliable for the D20? Are they easier and cheaper to find than a D300?
__________________
Old 04-17-2006, 05:49 PM   #5
EMTimZJ
EMTimZJ's Avatar
3.15:1 can be found here:
http://www.wildhorses4x4.com/41.asp
and 4:86:1 can be found here:
http://www.bcbroncos.com/drivetrain1.html
Mine was easy. I ordered it from a junkyard for $75 when I scoured all the local yards and found nothing. I used www.car-part.com
-Tim
__________________
-94 ZJ-
Old 04-18-2006, 01:21 AM   #6
violatedppl
violatedppl's Avatar
violatedppl will become famous soon enoughviolatedppl will become famous soon enough
Send a message via AIM to violatedppl
I think you just gave dirk another thing the wrap his mind in good job.
__________________
08 tundra double cab 5.7 4x4
I am jeepless at the moment.
Sold- Stock 03 WJ, 4.7HO. lift coming soon.
Sold-97 ZJ laredo 4.0, 242 RE BB, 31" BFG MTs, custom rear storage boxs, magnaflow hi flow cat, flow 70 series, 2.5 inch exhaust, jks quicker discos and some other crap
http://www.cardomain.com/ride/2221028
violatedppl is offline   Reply With Quote
Old 04-19-2006, 12:55 AM   #7
Swamp boy
MallCrawlin Supporter
Swamp boy's Avatar
Swamp boy will become famous soon enoughSwamp boy will become famous soon enough
Send a message via MSN to Swamp boy
Nice job...
Finished pics????
__________________
Swamp boy is offline   Reply With Quote
Old 04-19-2006, 01:46 AM   #8
Kraqa
Pinch Yo Sack Pimp
MallCrawlin Vendor
Kraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud ofKraqa has much to be proud of
Send a message via AIM to Kraqa Send a message via MSN to Kraqa
nice!!!!
the d20 is a very underrated t-case with the jeep guy's.
__________________
2008 Grand Cherokee "Kraq-O-Lantern"
TOYO TIRES RACE TEAM
| Longfeilds | Dana 60's | Coil Overs | Rear Stearing | Atlas | 4.3L Vortec |
Big Thanks To:
Jeap Thrills Customs Big B 604.465.5559
Redwood Plastics Greg Smith 604.607.6000
4x4 Oil.com Dirk
Hillside Auto Detail
Kraqa is offline   Reply With Quote
Old 04-19-2006, 11:46 AM   #9
EMTimZJ
EMTimZJ's Avatar
Thanks for the replies.
I have the first coat of paint on it, and when I have the painted portions assembled I'll post up some pictures. It will probably be Saturday or Sunday.
I will also put up what I will use for the twin-sticks and linkage. Which I have not decided 100% on.
-Tim
__________________
-94 ZJ-
Old 04-23-2006, 01:30 PM   #10
spykosshow
spykosshow's Avatar
spykosshow is a jewel in the roughspykosshow is a jewel in the roughspykosshow is a jewel in the roughspykosshow is a jewel in the rough
Send a message via AIM to spykosshow
Ok, it's sunday...where are these pics?!
spykosshow is offline   Reply With Quote
Old 04-23-2006, 11:43 PM   #11
EMTimZJ
EMTimZJ's Avatar
Charlie, good thinking. Here ya go.
Before:
After:
Enjoy.
-Tim
__________________
-94 ZJ-
Old 04-24-2006, 01:22 AM   #12
BlaineWasHere
BlaineWasHere's Avatar
BlaineWasHere is on a distinguished road
Send a message via AIM to BlaineWasHere
Tim... thats fucking pretty!
__________________
Grand Valley State University
BlaineWasHere is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
All information Copyright MallCrawlin LLC. Jeep is a registered trademark of DaimlerChrysler and is no way affiliated with this site. All posts are the property of the posters and are not the responsibility of Mallcrawlin LLC, it's affiliates, web hosts or associated companies.
