Been a lurker here a long time figured I would put some pics up of my build.
03 GC 4.0L Laredo
Suspension
Bilstein 5100 (f) and 5125 (r) shocks, KOR Dual SS Setup, Addco 1" Rear Sway Bar, 4.5" Clayton Springs with 2" p
ucks for a total of 6.5", KOR Sliders, JKS Quicker Disconnects, Iron D44 Rear
Swap, Clayton Long Arms Front and Rear, Carolina DS front Double Cardan DS, JKS
Tie Rod and Drag Link, JKS Adjustable Front Trackbar with Super Hard Bushings,
rotated knuckles, tank tuck.
Tom Woods SYE and Custom Rear Driveshaft. 4.10 gears front and rear, ARB
locker in Front and Rear.
Engine
63mm bored throttle body, K&N FIPK with AEM Filter
Summit Transmission Cooler and Remote Filter
Sunpro Transmission Temperature Gauge
Recovery
ARB Bumper, Mile Marker SE9500 Winch with Synthetic Rope
Mopar Factory Hitch Receiver
Custom skid plates
Highlift Jack
Homemade 15lb CO2 setup
Wheels and Brakes
Cragar 15x8 Soft 8s, BFG ATs 35 x 12.5 x 15
PFC Pads, Slotted and X-Drilled Summit Rotors all 4 corners W/ GoodRidge SS
Brake Lines
Electrical
Optima Yellow Top to keep it all running
Pioneer AVIC-F900BT Double Din Navigation unit with Sirius
Satellite, Alpine 250w Amp, Alpine Type S (doors), Infinity 3.5" Tweeters and
Basslink Subwoofer
500watt Power Inverter hardwired in
3rd Generation Projector Headlights with 55watt 4300k HIDs and Digital
Ballasts on dedicated relays.
Cobra Model 75 CB radio and Firestick Antenna
Hardwired Cobra Radar/Laser Detector
Viper Security System to keep the bad guys away.
Misc.
Yakima Mega Warrior Roof Rack with extension, spare tire, and tool
mounts.
Driving lights on roof rack
Smittybuilt Gear Seats both front seats
Iron 44 Install
Leftovers
Interior Mods
Trans Temp with Sensors in return line and Pan
Inverter
Double Din Head Unit
SmittyBuilt Seat Covers
Hard Wired Radar Detector
ARB Controls
Winch Controls
Lights
Rear Removeable Seat Mod
First Aid and Fire Control
Amplifier front edge of Sub Woofer
Infinity Basslink
Handy work light and defense in a pinch
Iro Long Arms, maybe claytons in January
JKS Trackbar, Tie Rod and Drag Link with KOR Dual SS Setup
Currie Johnny Joint on Front Upper CA
Homemade Front Bumpstops
Wifes ride
my other toys
Looks good. Does that LCA hit the old bracket, it looks really close?
That rear axle is... interesting... Did you weld the old tubes onto the new axle? If so, I hope there's at least a long, very tight-fitting sleeve in tubes. A bigger truss would be a VERY good idea.
no they do not hit, but I am planning claytons and then they will get cut clear off
No we chopped the old ends off the iron d44 and then cut my tubes off the D44a and then welded them back together with a sleeve inside each. Width is factory and all of the factory stuff still works including abs and parking brake, uses factory D44 WJ axle shafts.
Chase's team at East Coast Gears did the work, might length the truss at some point but I think it is pretty strong, the truss is welded right at the splice and the rear cover is attached tothe truss as well so it should not be going anywhere.
Dude maybe its my eyes but in the 5th pic your housing is cracked on the left side near the axle tube joint.
its just you.
Theres a Sleeve inside the tubes? how does that work with the oiling of the outer bearings? And why did you choose to put the trans temp gauge in the return line?
What plate carrier did you use to wrap around the seat ? I love that idea.
the oil level is higher now with the new rear cover, the oil is above the half way mark i the diff so plenty of oil tothe bearings
Well I put the temp gauge in the return ine before I got a bung welded into the tranny pan, just left it after I got it welded.
not plate carriers, smitty built seat covers.
Well I have decided to build me own bumper.
Here are the beginnings of it. It is the basic frame waiting on the tire swing pieces to come then I am going to box it all in with 12 ga steel.
will add more as I progress, waiting on the kit now.
Tire Carrier Swingout Component Builders Kit
added swing arm pivot
base swing arm
closure
a little style
side closed in
top plate
angled back under
started boxing top in
top of side box
tire mount add
gusseted
still more work to do but got a lot done, need to do a lot of welding and a few more pieces to fill in gaps around door and fenders.
I think the bumper is done, will take it off, add a few welds from the back side, weld up all the seams and the grind and paint.
I also think I am going to order a CO2 tank bracket and mount it on the drivers side for carrying my CO2 tank.
Add a cross bar that fits really tight and nice between the top of the receiver and the bottom of the horizontal bars I welded to the side of the hitch receiver mounting plats. I think it will nicely add to the strength, also may add a couple of verticals between it and the main cross piece once it is off for finishing.
Hopefully will be able to finish it up over holiday closure at work, then it is clayton time.
Nice try.. Seems a tad bulky though. JMHO
To each his own. It doesn't look like you wheel it very hard and doubt it will drag on a speed bump so whatever.
Runsfine have to spread it LOL
you guys are tougher than my wife, I do wheel it, not as often as I would like because of other family interests, but it does get beat on a few times a year, hopefully more this coming year as I stepped down as scoutmaster of my son's troop.
had not thought about it being there in an accident, might reconsider or make it removeable for only when I am on the trail.
I do agree with jeeptech01, it seems a little bulky, like a fat woman who had lypo everywhere except her ass. You might want to move up the tire mount as well
