MallCrawlin.com Forums
Go Back   MallCrawlin.com Forums > Tech > Suspension & Steering
User Name
Password
Home Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Suspension & Steering Advanced Technical Discussion regarding suspensions and steering on ZJ's and WJ's
Reply
Thread Tools
Old 02-08-2010, 05:02 PM   #1
rstrucks
TOTM Guru
Lifetime Supporter
rstrucks's Avatar
rstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud ofrstrucks has much to be proud of
High steer drilling
Is there a good rule of thumb to figuring out where to drill a high steer arm for the drag link. I know I can cycle the st. box and cycle the tie rod and try to match up the "throw", I'm just curious if there is a different way.
My arms are already drilled for the tie rod, just not the drag link. I'm running the stock box (for now) and I need to drill tonight!
__________________
'98 5.9 - long armed, locked, 37's.
rstrucks is offline   Reply With Quote
Old 02-08-2010, 05:10 PM   #2
ATL ZJ
ATL ZJ's Avatar
ATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond reputeATL ZJ has a reputation beyond repute
Send a message via AIM to ATL ZJ
Re: High steer drilling
Mounting your tie rods closer to the knuckle gives you more travel, (greater steering arc/faster response) but less leverage on the knuckle. Mounting them farther away reduces your steering angles for the same amount of input at the steering wheel.
Maybe you already know that, but I figured it was worth saying either way. The terminology gets a little bit tricky because in your case the drag link end is doing the same job that tie rod end in a full hydro setup does, so that is why I said tie rod.
ATL ZJ is offline   Reply With Quote
Old 02-08-2010, 05:46 PM   #3
paulkeith
paulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant futurepaulkeith has a brilliant future
If you know your u joint deflection angle, you can use some trigonometry to figure out the linear travel of your tierod versus distance to the balljoint/kingpin.
Set that equal to whatever your linear travel is lock to lock (or what you want lock to lock to be) on your steering box/pitman arm combo, and you should get your distance.
.......if you want to get technical about it.
paulkeith is offline   Reply With Quote
Old 02-08-2010, 05:56 PM   #4
IndyZJ
IndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud ofIndyZJ has much to be proud of
Send a message via AIM to IndyZJ
I was under the impression that the center to center measurement of the pitman arm is supposed to match the distance from the center of the balljoint/ kingpin to the center of the draglink hole on the steering arm to maximize steering angle and minimize effort. Is this not true?
__________________
Quote:
Originally Posted by FearTheDentist View Post
I realize I'm biased, but I can't quite get past the jacked up teeth...
IndyZJ is offline   Reply With Quote
Old 02-08-2010, 05:59 PM   #5
ATL ZJ
ATL ZJ's Avatar
You also need to think about where you locate the hole in relation to how you want your ackerman to end up. that is if your arms are wide enough to allow some inboard/outboard adjustment...
Old 02-08-2010, 08:17 PM   #6
zj95maxx
zj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant futurezj95maxx has a brilliant future
Send a message via AIM to zj95maxx
Quote:
What he said.
__________________
Uber one Ton ZJ Tech
PSC Full Hydro Tech for ZJ
zj95maxx is offline   Reply With Quote
Old 02-09-2010, 12:16 AM   #7
rstrucks
TOTM Guru
Lifetime Supporter
rstrucks's Avatar
I thought thats what the rule was but wasn't sure.
I didn't get around to drilling the hole tonight as I ran out of time. Maybe tomorrow.
__________________
Old 02-09-2010, 12:18 AM   #8
rstrucks
TOTM Guru
Lifetime Supporter
rstrucks's Avatar
Quote:
Both tie rod holes are already drilled at the end/inboard side of the arm. I just need to add an attachment point for the drag link.
__________________
Old 02-09-2010, 01:30 PM   #9
ATL ZJ
ATL ZJ's Avatar
Quote:
Disregard my comment then, and forgive me for being stuck in the full hydro mindset and low on sleep!
Old 02-09-2010, 01:51 PM   #10
rstrucks
TOTM Guru
Lifetime Supporter
rstrucks's Avatar
forgive me for being low on sleep!
I hear ya.
I should get some R and R this weekend though.
__________________
Old 02-11-2010, 12:43 PM   #11
rstrucks
TOTM Guru
Lifetime Supporter
rstrucks's Avatar
Just to update;
IndyZJ was right - it turned out that the correct distance is nearly identical to the pitman arm center to center measurement. I ended up welding a bracket on to my high steer arm to attach my drag link to. That way seemed to work out the best. I'll have pics of it in my build thread soon.
Thanks
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
All information Copyright MallCrawlin LLC. Jeep is a registered trademark of DaimlerChrysler and is no way affiliated with this site. All posts are the property of the posters and are not the responsibility of Mallcrawlin LLC, it's affiliates, web hosts or associated companies.
