Hokies 98 build
Thread: Hokies 98 build
Results 1 to 25 of 25
  1. #1 Hokies 98 build
    Member hokie98zj's Avatar
    Feb 2008
    VA
    as it sits now:
    claytons long arms
    6"s
    35" Maxxis Buckshot Mudders
    hp30/d44 w/ 4.88s,locked & stuff
    231 w/sye
    woody's f&r
    Currie Hd steering
    kor tbc
    jcr stage IIs
    warn lockouts
    been lurking on here for a while but no build thread since i didnt have much done yet.started with a stock 98 limited in august of 07.
    i knew i wanted a grand cherokee and had a little plan on what i wanted to do.3 months after buying it,i bought a RC 4" lift,tom wood driveshafts and 32" bfg a/ts
    the front tires did rub a little,did some trimming and then ordered a kor front stealth so i ripped off the stock cover
  2. #2 Re: Hokies 98 build
    Feb 2008
    VA
    had the kor bumper put on and added a cb radio with 3' firestik after not being able to talk out on the trail when i needed to
    next thing added on was a set of JCR stage II sliders
  3. #3 Re: Hokies 98 build
    Feb 2008
    VA
    i ordered claytons long arms front and rear and bought some built axles from a guy in my club.front is an hp30 with yukon super joints,arb,alloys,warn lockouts,currie hd steering and 4.88s.rear is a tj44 with an arb and 4.88s.when i get the money i will order alloys for that as well. right now my rig is at matts(moonworks) getting all this put in.
    was going to have it done at a local shop but they didnt seem to know squat about zjs.
    plans are to add some 2" spacers(will be here tomorow-got in on the 5.80/spacer deal from teraflex),trim as needed and throw some 35s on.swap in a 231 also and quick discos.
  4. #4 Re: Hokies 98 build
    Feb 2008
    VA
    here are some pics from a local trail i went to to get a little dirty(sorry again matt)
    let me know what you guys think.when i get it back from matt,i will post up pics of the long arms/axles
  5. #5 Re: Hokies 98 build
    Dinwiddie, VA
    Quote Originally Posted by hokie98zj View Post
    I'm so tired of that shit getting in my eyes it's not funny!
    "Matt"
  6. #6 Re: Hokies 98 build
    Feb 2008
    VA
    i was underneath looking around before i left for your place and a bunch got in my eyes as well.would be cleaner but the local car wash wont let me in but to clean the interior
  7. #7 Re: Hokies 98 build
    Dinwiddie, VA
    Little update to what Brandon has gotten done to his rig here recently.
    Clayton LA's, 2" spacers up front of his 4.5" springs, swapped both axles, 44 rear got stripped down and all new Ballistic brackets welded in w/ a claytons truss, 231 swap w/ new AA SYE and new Tom Woods rear drive shaft, Kevins trackbar conversion w/ JKS adjustable trackbar. I didn't gear the axles but both axles have 4.88 gears w/ ARB's, rock crusher covers, and the front has alloy shafts and manual hubs. Slider also had to be modified a little to fit with the claytons brackets so they got welded on as well. He also got a couple new stickers for a bit more HP! lol
    I'll let him update this with some wheeling pics!
    "Matt"
  8. #8 Re: Hokies 98 build
    Feb 2008
    VA
    alright im finally getting around to adding some pictures of the long arms and axle swap.
    dropping it off
    front crossmember going on
    frame stiffeners
    muffler gone
    look Ma, no wheels!
    hp30 in
    truss on the 44
    turdy 5 gone
  9. #9 Re: Hokies 98 build
    Feb 2008
    VA
    44 painted and ready to go in
    44 cover with some extra paint
    rear arms done
    new driveshaft
    kor track bar conversion
    workin on the t-case/sye swap
    231 w/sye in
    and of course the finished product
  10. #10 Re: Hokies 98 build
    Nov 2008
    RI
    Wow fast build, looks great.
  11. #11 Re: Hokies 98 build
    Houston, TX
    frame stiffeners
    It is probably just hte pic but the rear mount looks like it has MASSIVE burn through....
  12. #12 Re: Hokies 98 build
    Dinwiddie, VA
    I think I see what you're talking about...that's a factory hole in the frame. I didn't burn through in any spots surprisingly enough. I've got the welder dialed in pretty good now. In the past I'd burn through here and there a little and I'd have to go back and fill it but not on his.
    "Matt"
  13. #13 Re: Hokies 98 build
    Feb 2008
    VA
    picked up some 35s from a guy in my club.mounting them on my current 15x8s and selling the 32s.
    should be on in a week or so then i can figure out bumpstops,limiting straps(see pics below),etc.
    probably picking up a tow hitch receiver this week then some armor.
    also got the the exhaust done about a month ago.just got something called a double banana(almost a straight through) to pass inspection.
  14. #14 Re: Hokies 98 build
    Sep 2008
    Mesa, Arizona
    Jeep looks awesome except for the roof rack.
  15. #15 Re: Hokies 98 build
    Feb 2008
    VA
    i just put that on again a couple days ago after it being in my basement all winter.taking it off again tomorrow with it dropping my mpg a little bit.but for 40 bucks its not bad
  16. #16 Re: Hokies 98 build
    Feb 2008
    VA
    sold the roof rack.
    have a question.whats the maximum about of thread that can safely be showing on the lower control arms?right now there is about an inch of thread showing and i need to push the axle forward some more.
  17. #17 Re: Hokies 98 build
    Midlothian Virginia
    The clayton arms are 2.5 inch long joints. I would not thread out the joint more than an inch and a half.
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  18. #18 Re: Hokies 98 build
    Member zjrog's Avatar
    Jan 2007
    Tooele
    SO did you do the Warn lockouts? Or get the axle with them in? If you did them, did you get any pics along the way?
    1995 ZJ Laredo 4x4 Upcountry package
    1990 XJ Special PIA edition
    1990 Ford Ranger 4x4 2.3
    2002 Ford Supercrew 4x2 5.4
    2003 Dodge Neon SE "Half-a-Hemi"
  19. #19 Re: Hokies 98 build
    Feb 2008
    VA
    Quote Originally Posted by Gb02WJ View Post
    i wouldnt call it a fast build.i've had the jeep for almost 2 years.ran a 4" rough country for about a year and a half.picked up the axles a while back and waited until i bought the front and rear clayton kits and other parts and the stuff got put on all at once.when i get some free time and if the weather stays clear,i have some quicker discos to put on.also planning on having 35s mounted this week as well.
    picked up a free spare tire in good shape with a decent amount of tread left.not an m/t but will get me by until i buy a better one.
  20. #20 Re: Hokies 98 build
    Feb 2008
    VA
    Quote Originally Posted by zjrog View Post
    bought the axles already built so no pics of those being installed
  21. #21 Re: Hokies 98 build
    Feb 2008
    VA
    before:
    after:
    got the 35" Maxxis buckshot mudders mounted earlier today before work.got them for 500 from a guy in my club and they are nearly new.
  22. #22 Re: Hokies 98 build
    Sep 2008
    Mesa, Arizona
    Looks really good man.
  23. #23 Re: Hokies 98 build
    Jan 2008
    Wichita, KS
    I like it.
  24. #24 Re: Hokies 98 build
    Dinwiddie, VA
    Nice!!!
    "Matt"
  25. #25 Re: Hokies 98 build
    Senior Member greengc4x4's Avatar
    Feb 2008
    lima,ohio
    Looks great man. Makes me want 35's
    '98 ZJ 5.9L Ltd
    UC Springs/.5" spacer/MX6 Shocks/SCT Tuned/BBK 52mm TB/K&N FIPK/Amsoil Filter/"Jeep" Valve Covers/Doug Thorley Headers/Random Technologies Cat/Magnaflow/"Kolak" Ignition/Optima Redtop/Lotek Dual Pillar Pod/AEM Tranny Temp Gauge/Mag-Hytec Tranny Pan/RB1 WJ Nav/Vancos/EU Headlights and Turn Signals/Turn Signal Mod/JKS Disconnects
    Waiting to be installed
    M1/Insulated Fuel Rails/24lb FMS Injectors/Underdrive Crank Pulley/Walbro Fuel Pump/Prothane Bushings/Hotchkis Swaybars
