Well so far it looks like ballistic is the way to go, pretty cheap, and I know they make quality products. Thanks for posting pictures and links, it helps out a lot. As far as these go, what is the purpose, do I need them, or can I go without?
I have these up top to hold the coil. 29.99
http://www.ballisticfabrication.com/...p_32-1478.html
new to the forums, but this seems to be the site for heavy modding, I have a 8.8 sitting in my basement ready for brackets, I like the look of the balistics and seems to be alot cheeper then buying a MORE kit. I am having a local fab shop do all the measuring and welding, if i buy those brackets is that all i need for the UCA and LCA and spring perches?? is there anything special they are going to have to do them as in modding them to make my axle sit right? what are ya guys using for trac bar brackets?? ect.
Jason
Ok well, if your going to a long arm kit you will most likely have a truss which means a 4 link suspension, which also means the track bar is eliminated. If your not going to the long arm kit you will need UCA, LCA, Buckets, Shock mounts, and a track bar mount. Im sure you can find a track bar mount on ballistics. All the 4X4 shop will do is set your pinion at a certain degree, 11 seems to be popular, and then set your perches and mounts at 0 degrees, or right on top of your axle depending on how you look at it. They shouldn't have to do anything else to make it fit right as long as you order the right bracket, which i believe is for a 3.25" axle. Correct me if im wrong on any of this.
For some reason they don't have it on their site but he has them in stock ready to ship. Brown dropped my kit off today and I ordered it Friday.
Here is a photo of their kit:
I liked that it had everything included and at $225 I thought it was a good deal.
I'm glad everyone is posting up the fabricators, part #s and combination of brackets they bought. AW's thread is constantly growing and makes for a great reference.
Now if I can only find someone to machine my 3/4" spacers.
Why not check out Claytons Axle Bracket kits...
All made from 1/4" Plate and all high clearence. Nothing hanging below axle tubes !
Nothing serious, yet. I've played on a gravel pile or two just to watch the suspension cycle and haven't seen any problems arise. Really, the only change is how far away the control arm bolt holes are from center of the axle tube. Given the difference in tube diameter (3.25" on the 8.8, 2.62" on the 35), my lower mounts were a little bit longer by ~1/2" and the uppers were shorter by less than 1/8" compare to stock. I'm using adjustable control arms, so the angles can be fixed if need be. Just make sure to use an angle finder and measure a lot before welding it on fully.
Edit: I modified the shock mounts and had to put them inboard a little. Not the best setup and I might have to redo it. You can see in the pic bellow (zip ties are temporary until I find the right type of clips).
So do they sell a kit like this one that doesnt have upper controll arm mounts? Cuz it would cut the cost down, and I really dont need them.
Also thought about calytons, but damn, expensive.
Im really leaning towards ballitstics though.
Anyone have any trouble re-installing the stock ZJ sway bar on an 8.8? If it's truly 1.25" narrower, is there room between the coil bucket and the brake backing plate for a sway bar bracket?
I dont run a rear sway bar right now and have had no trouble. With how much lift you are at you are probably fine without one. I haven't installed my 8.8 yet so I cant help ya there.
I just got around to seeing your 8.8 upgrade........great job!! I want to do the same upgrade in TJ, but I had a few concerns (actually I just posted a thread on this same topic which I am sure I will get bitched at for) anyway, where did you get your axle brackets for the 8.8 at? Also, how did you decide on the 11 degree pinion angle? Thanks for any input.
Hey AprilzWarrior, I have Grand that I am swaping a 8.8 and I was wondering that if I had to get wheelspacer even with my rims that are 15-8s with about 4" backspacing? All the input would be great.
Dirtdiver, my wheels have 4" backspacing as well but it's definitely nice to have the spacers there since the 8.8 is 5/8" narrower on each side.
Dont have my 8.8 in yet, but i dont think they are NEEDED. you might run into some rubbing issues when your suspension articulates, but if it were me i would just spent the 90 bucks and get some spacers. Hell you could probably find some used ones if you looked hard enough, but who knows.
I hate spacers.... I have em.... i dont run themmm ... i need to sell them
not worth it... and you really dont notice the width diff unless i point it out
How much you looking to get for them
Its not that I dont wnat them I'm just looking if I really need them. I could spend the money on something else.
