Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2962
Biggoofy's 96 ZJ build! ** HP44 and 9" swap ** - Page 3
Thread: Biggoofy's 96 ZJ build! ** HP44 and 9" swap **
Page 3 of 36 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 885
  1. #51 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Quote Originally Posted by CrawlerReady View Post
    Only thing I would change is use countersunk allen head bolts. Is that 1/8"? Looks pretty thin so I'm not sure the countersunk bolts would work well.
    it is 1/8" and I can counter sink them just havent decided if i want to I'm thinking a nice allen pan head will do just fine.
    93 ZJ long arms, 35's, F/R Long arms, 4.56 gears, and a bunch more
    98 5.9 slate gray 4" lift with stuff (sold)
    96 ZJ Lift, Long arms, 35's and a bunch of other shit! (RIP)
    [ IRONMAN 4X4 FAB ] [ RACELINE WHEELS]
  2. #52 Re: My money pit!! 96 ZJ build
    Lufkin, TX
    Quote Originally Posted by biggoofy View Post
    To each his own my friend no offense take at all these are just the start I plan to expand on them and they will have backing plates to add much needed strength.
    If you had a cage and tied them into it it would be more structurely sound. IMO
    No longer a JeepTech01 fan.
    Just boobs.
    And biggoofy.
    And ELLLLLIOTTTTT................I think..........Yup and ELLLLLIOTTTTT.
  3. #53 Re: My money pit!! 96 ZJ build
    Lufkin, TX
    So how's that body lift coming along?
    Just boobs.
    And biggoofy.
  4. #54 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Ok so I finally changed my oil today and after 23,000 miles and it still looked really good but for sure needed a change she runs a tad smoother but not a big difference. Amsoil is a great product thats for sure!
  5. #55 Re: My money pit!! 96 ZJ build
    Lufkin, TX
    lots of turdness here
    Just boobs.
    And biggoofy.
  6. #56 Re: My money pit!! 96 ZJ build
    Lufkin, TX
    i demand an update!
    Just boobs.
    And biggoofy.
  7. #57 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Well Yukon 4.88s and master install kits are paid for along with some 2x4 .25 wall for the mini boat sides!! East coast gear supply hooked it up for sure. Big thanks to Chase the owner for great service and pricing.
  8. #58 Re: My money pit!! 96 ZJ build
    zzz... Lifetime Supporter JolleyRoger's Avatar
    Portsmouth, NH
    o and my charcole canister is semi mounted now
    I did a double take, because that is exactly the way mine is mounted. White zip ties and all.
  9. #59 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Yeah they seem to work well. lol
  10. #60 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Well looks like me and my buddy Len are going to have a very productive weekend. Mini boat sides are a go. I'll be starting friday and I'll also be cleaning up my axles and getting them ready for the regear.
  11. #61 Re: My money pit!! 96 ZJ build
    Pics! Watch that shoulder.
    2004 Ford Lightning
  12. #62 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Well the plan was to start today but getting the steel took longer than thought and i helped my buddy replace the fuel pump in his zj so the cutting and welding begins in the am
    2x4
    4.88 gears for the hp30 and 8.8
  13. #63 Re: My money pit!! 96 ZJ build
    Lufkin, TX
    lookin like a fun filled weekend.
    Just boobs.
    And biggoofy.
  14. #64 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Well I got pretty far today on the passenger side and I must say a plasma cutter is the way to go when doing a boat side saved me a few hours at least. What really takes a lot of time is cutting and reshaping the A and C pillars then re-welding them **** that thin *** sheet metal.
    first cut was with a sawsall to oper her up and take a look
    the C pillar area before any cutting was done the is just with the outer skin removed
    the A pillar before any real cutting was done
    under side of A pillar area
    B pillar prior to cutting
    C pillar after being cut and modified
    A pillar during cutting and rework
    view after 90% of the cutting they are cut as high as i can go with out cutting the doors or floor pans
  15. #65 Re: My money pit!! 96 ZJ build
    Senior Member it usually runs fine's Avatar
    Beaumont, Texas
    So it begins.
    Some girls don't like guys like me, but some girls do.
  16. #66 Re: My money pit!! 96 ZJ build
    Looks good. How are you going to tie the 2x4 into the pillars? I noticed you left your tiny pinion in the bag for the picture LOL
    2004 Ford Lightning
  17. #67 Re: My money pit!! 96 ZJ build
    Member Stroked X's Avatar
    Oct 2007
    Surrey B.C. Canada
    looks good cut out rock sliders FTW
    2000 Ford Excursion 4x4 7.3l Powerstroke Diesel, 8" DR Lift, 38x15.5xr20 Micky Thompson MTZ. 20" Jesse James Lawless 8, 4" exhaust, AFE intake, DP-Tuner Chip 140hp chip, Garrett BB Turbo, H.I.D's, Billet grill and lots more.
    1998 Jeep Grand Cherokee 4x4 5.2l v8, 4.5" lift 33" tires, Aussie locker, K&N intake, Flowmaster, high flow cat, sway bar disconnects, 242 transfer case, u-joint front axle.
    http://i109.photobucket.com/albums/n...ni/jeep-zj.jpg
  18. #68 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    yeah its nice and small haha and I'm posting pictures of the brackets but i used a 2x4 3/16 bracket welded to the A,B, and C pillars.
  19. #69 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    OK well today was very eventful caught my jeep on fire twice lol but everything is ok and nothing major was damaged but it was a learning experience. During the welding on the passenger side make sure the main harness is pulled away from the metal along with the plastic or is will catch fire ask me how I know that one lol.
    A pillar 3/16th bracket welded in
    B pillar bracket welded in
    C pillar bracket welded in
    A,B, and C brackets welded in
    2x4 mocked in
    2x4 mocked in
    2X4 welded in and painted sorry for the ****ty pic
    2x4 welded into the A pillar bracket
    2x4 welded into the B pillar bracket
    2x4 welded into the C pillar bracket
  20. #70 Re: My money pit!! 96 ZJ build
    Member zj6.5's Avatar
    Sep 2010
    Friendsville,TN
    Looking great!!!
    If it ain't broke.... We ain't done yet!!!
  21. #71 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Well got it all finished up today still need to add the 2x2 kicker rails. I measured the lowest point on the drivers side rockers at 16 inches and the passenger side at 19 inches so a 3" total gain and 5" if I were to have had sliders mounted under the rockers. :cheers2:
    I also still need to cap them so ill be doing that this week at some point
  22. #72 Re: My money pit!! 96 ZJ build
    Senior Member dp96zj's Avatar
    Texas
    Looks good man. Throw some semi-aggressive 33's on there and that thing'll be pretty capable.
  23. #73 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Thanks man! It will be on 35s in march
  24. #74 Re: My money pit!! 96 ZJ build
    Tits man! That extra couple of inches makes more of a difference than you could imagine, it's incredible. You'll love the hell outta it!
  25. #75 Re: My money pit!! 96 ZJ build
    Jan 2010
    SLC UT
    Thanks man now I just need to do the other side lol
