Stage II - bigger, heavier, slower. - Page 8
Thread: Stage II - bigger, heavier, slower.
Page 8 of 10 FirstFirst 12345678910 LastLast
Results 176 to 200 of 249
  1. #176 Re: Stage II - bigger, heavier, slower.
    Tn
    Rear wheel well work in progress.
  2. #177 Re: Stage II - bigger, heavier, slower.
    Nice fit. Is the cooler on the sway bar?
    2004 Ford Lightning
  3. #178 Re: Stage II - bigger, heavier, slower.
    Senior Member faststang1's Avatar
    Sep 2007
    Palm Spring's CA
    rstrucks,Ur ZJ is going to look badass.After looking at ur work,it making me want a tube fenders and exo cage.
    Great work.
    96 ZJ Limited, 5.2 with K&N filter, Hi flow cat, Cherry bomb extreme muffler, Clayton long arms 6" lift, Steering box brace from KOR, KOR track bar Conversion,TnT steering, 242 TC, 8.8 with ARB Locker, dana 30, 4.88 gearing, 35 KM2's
    KOR bumpers
    http://www.mallcrawlin.com/forum/showthread.php?t=17149
    07 CRF250X
  4. #179 Re: Stage II - bigger, heavier, slower.
    Jul 2008
    North Carolina
    Awesome man, can't wait to see it at GSSE!
  5. #180 Re: Stage II - bigger, heavier, slower.
    looks rad!
    those steering coolers are jeeeeeeuuuunk!
  6. #181 Re: Stage II - bigger, heavier, slower.
    Member leeanderthal's Avatar
    Jul 2008
    Benton Harbor, Michigan, United States
    Looks real good. I like the "tube fenders". The hydro assist looks good also.
  7. #182 Re: Stage II - bigger, heavier, slower.
    Tn
    Nope, it's mounted to the steering box brace.
    That figures. I had two different style coolers to choose from. Junk because they are inefficient or because they leak and/or don't hold up?
  8. #183 Re: Stage II - bigger, heavier, slower.
    Beaumont, Texas
    looks rad!
    please explain i was wanting to get one, why are they junk?
  9. #184 Re: Stage II - bigger, heavier, slower.
    Senior Member greengc4x4's Avatar
    Feb 2008
    lima,ohio
    I hope your sunroof motor never goes out. lol. That is a badass cage.
    '98 ZJ 5.9L Ltd
    UC Springs/.5" spacer/MX6 Shocks/SCT Tuned/BBK 52mm TB/K&N FIPK/Amsoil Filter/"Jeep" Valve Covers/Doug Thorley Headers/Random Technologies Cat/Magnaflow/"Kolak" Ignition/Optima Redtop/Lotek Dual Pillar Pod/AEM Tranny Temp Gauge/Mag-Hytec Tranny Pan/RB1 WJ Nav/Vancos/EU Headlights and Turn Signals/Turn Signal Mod/JKS Disconnects
    Waiting to be installed
    M1/Insulated Fuel Rails/24lb FMS Injectors/Underdrive Crank Pulley/Walbro Fuel Pump/Prothane Bushings/Hotchkis Swaybars
  10. #185 Re: Stage II - bigger, heavier, slower.
    Looks great, Ryan!
    Did you ever pinpoint what that squeaking was at Windrock?
  11. #186 Re: Stage II - bigger, heavier, slower.
    Tn
    A dry front control arm joint. I had adjusted and lubed all the rear joints before that trip. Time to do the fronts.
  12. #187 Re: Stage II - bigger, heavier, slower.
    10-4
    2004 Ford Lightning
  13. #188 Re: Stage II - bigger, heavier, slower.
    they just don't seam to pull enough heat out.
    for hydro assyst they might be OK as long as your not bouncing off the rev limiter all the time.
    i have a 15" right in front of my radiator that is being cooled by a taurus 2 speed fan on high and it can't keep up. its so bad that i stopped using my rear steer because if i was on the throttle i woudl kill th epump in no time.
    i will be adding a second cooler to my system. i just don't trust this style. i've been workign with PSC for three years on this and the end result is that cooler style doesn't work for high heat applications. good thing PSC has a good warranty. its their cooler from their "kit".
  14. #189 Re: Stage II - bigger, heavier, slower.
    what fluid are you running?
  15. #190 Re: Stage II - bigger, heavier, slower.
    Tn
    Ok, cool. I think I'll be in good shape as I'm not a total throttle junky and I'm just running an assist system.
    Yeah, that's why I went with this style. I'll be running Royal Purple Max EZ fluid. I have heard good things about Amsoil's fluid solving foaming and overheating problems though and will try them if I have problems.
    Thanks for the input.
  16. #191 Re: Stage II - bigger, heavier, slower.
    Beaumont, Texas
    Ive had good luck with tractor hydraulic fluid as far as bubbling goes, supposedly it runs cooler also.
  17. #192 Re: Stage II - bigger, heavier, slower.
    SL,UT
    This is what I run in my full-hydro system. Been good so far and haven't had any issues/bubbles.
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  18. #193 Re: Stage II - bigger, heavier, slower.
    Damn man I really like the work your puttin out on this thing, it looks great! I don't know if I said this about your cage earlier, but I think you found the perfect location for that C-hoop crossbar, tucked in right at the top of the seat and bottom of the headrests. I like that A LOT, and plan to incorporate a similar placement in Andy's build
  19. #194 Re: Stage II - bigger, heavier, slower.
    Tn
    Thanks Greg. I'm trying (probably too hard) to make this a clean rig I can drive back and forth to work once a week without looking like a jungle gym and still provide some level of body protection. I should have the wheel well/fender tube protection done this week and I'll try to get the damn thing outside for some "beauty" shots with the cage and all done.
  20. #195 Re: Stage II - bigger, heavier, slower.
    Looks GREAT Ryan, you're doing a fantastic job!!
  21. #196 Re: Stage II - bigger, heavier, slower.
    Amsoil fluid is the way to go Ryan. All the comp guys are running it and it kicks ass.
    I'm just saying.
  22. #197 Re: Stage II - bigger, heavier, slower.
    May 2005
    Boone NC
    I'm just saying.
    all the cool kids are doing it
  23. #198 Re: Stage II - bigger, heavier, slower.
    Tn
    Thanks Dirk.
    Been driving the ZJ the last couple of days. Running good and ready for Harlan this weekend. There is still a short list of things to do but it should be good to go. When doing the exo portion of the cage I never could think of a way to tie in the rear of the roof rub-rail. Well, I finally know what I want to do but it won't happen until after GSSE. I also need to finish the last 20% of the frame plating.
    Anyway, here are some lame driveway pics (hopefully not to be known as the "before" pics).
  24. #199 Re: Stage II - bigger, heavier, slower.
    Good looking and fully functional don't always go together but I think you pulled it off. One of the cleanest full body grands I've seen over the years... hope it stays that way, kind of
  25. #200 Re: Stage II - bigger, heavier, slower.
    What he said. Easily my favorite cage design in/on a ZJ so far. I was going to ask how you terminated the "roof rails" a while ago - what do you have planned?
