Thread: 35 x 14 x 15" Rim Tire tube...
Results 1 to 15 of 15
  1. #1 35 x 14 x 15" Rim Tire tube...
    Jan 2008
    Minnesota
    So I went and bought some 35" Mud Tires for my ZJ today, they had some sidewall cracking but not too bad. They were pulled off a lifted ranger. Anyway, I found out that one of the tires leaks out the sidewall cracks. I was thinking I can either get an inner tube for the tire or get it vulcanized. Problem is I dont know where to find either of those. I am going to a tractor supply store tomorrow to ask, but i have no clue where to look for vulcanizing?
    Any tips greatly appreciated, I wanna save this tire before its too late.
    Thanks
    -Pat
    I'm 20 and getting my fingers cut while learning...
    98 5.9 ZJ, 6.5" F & R IRO LA's, 35" MTR's, 4.88 Gears, 8.8 w/Aussie, HP30, 242 w/ Skid, XRC8 winch, engine mods, etc...
  2. #2 Re: 35 x 14 x 15" Rim Tire tube...
    So they're dry rotted, and to the point of not being able to hold air? Hope you didn't pay much for them...
    edit: You might want to think about a different set of tires. If one won't hold air already, they're probably close to falling apart.
  3. #3 Re: 35 x 14 x 15" Rim Tire tube...
    Jan 2008
    Minnesota
    I paid $235 with the crager 15 x 10 imitation beadlock rims. All hold air but one. The others are rotting too though. I thought vulcanizing can fix that? And wont an innertube take most of the pressure instead of forcing the tire to hold the air?
  4. #4 Re: 35 x 14 x 15" Rim Tire tube...
    I would be worried about the tires seperating at any sort of speed, lots of friction and heat. Vulcanizing is basically melting the rubber back together, but its used in like a single sidewall cut instance, not the whole tire like your tires would need.
  5. #5 Re: 35 x 14 x 15" Rim Tire tube...
    Exactly. Even offroad it won't take long for the things to be ripped apart, but I'd still be more worried about them flying apart on the highway.
  6. #6 Re: 35 x 14 x 15" Rim Tire tube...
    Oct 2008
    LI, NY
    Quote Originally Posted by redhatman View Post
    An inner tube would help a little as a band aid. If its only that one sidewall crack, it'll keep the air in, but only until the crack gets big enough for the tube to start popping out. And that could happen in a matter of a few miles, depending on how rotted that rubber is.
  7. #7 Re: 35 x 14 x 15" Rim Tire tube...
    Tn
    Sounds like good money after bad. I'd keep the wheels and unload the tires.
  8. #8 Re: 35 x 14 x 15" Rim Tire tube...
    ^Yup.
    I'd hate to see you wreck your truck over crappy tires.
  9. #9 Re: 35 x 14 x 15" Rim Tire tube...
    Oct 2006
    Calgary, AB, Canada
    I wouldn't run them, too great of a risk of seperation, even with a tube. Maybe as a spare.....
    I think you just got your finger's cut.....
    '93 ZJ LTD, 5.2L, Claytons Hardarm, 8" lift D44 front(w/elocker), D60 rear(welded), 37" IROKS, 5.38s, 9.5ti
  10. #10 Re: 35 x 14 x 15" Rim Tire tube...
    May 2006
    York, PA
    Plus if you live in a state with inspection , sidewall cracking wont pass... do yourself a favor and go get some 35x12.50 and just use those wheels, if your low on cash try the mud king series, they just have weak sidewalls so be careful around rocks
    "Say fuck you to Mother Nature, and kick her in the face! "
    94 Limited- 4.5" ghetto lift, Ghetto 33x12.50 Mud Kings, Ghetto wheels, Crappy stickers, some dents, custom front bumper(too be mounted), Kevins rad. support.
    Looking for 1980s VW Rabbit truck
  11. #11 Re: 35 x 14 x 15" Rim Tire tube...
    Jan 2008
    Minnesota
    I ended up demounting the tires and selling them back to him for $135. I paid $100 for the 4 Crager Imitation Beadlocks 15 x 8 rims. I am going to pick up some 95% tread Mickey Thompson 35" x 12.50 R15 Baja Claw Radial tires within the next week or so. Pulled off a mudding Samauri with 24 inches of lift :O
  12. #12 Re: 35 x 14 x 15" Rim Tire tube...
    You're lucky the guy gave you something back. Just chalk it up as a lesson learned to take a good look at any (used) parts before purchasing, and do research where it is necessary before buying anything. Make sure there isn't any sign of rot or strange wear on the tires. You might even want to check the DOT code to see when they were made, as the design has been around for a while now.
    It really is good to hear that the guy didn't just completely screw you over... that's pretty rare anymore.
  13. #13 Re: 35 x 14 x 15" Rim Tire tube...
    Member Art's Avatar
    San Antonio, TX
    badass i love mt claws!
  14. #14 Re: 35 x 14 x 15" Rim Tire tube...
    Jan 2005
    Topeka, Kansas
    Excellent call!
  15. #15 Re: 35 x 14 x 15" Rim Tire tube...
    Jan 2015
    Temecula Ca.
    Does anyone know where to get inner tubes for 35 X 13.5 R 15 tires
    Dave
