Stock Rock'her
Thread: Stock Rock'her
Results 1 to 25 of 28
  1. #1 Stock Rock'her
    Aug 2007
    SLC, UT
    I'm kinda new to the ZJ stuff but I have an ok built XJ
    I just picked up a ZJ last week.
    Lemme kinda outline my goals with this.
    I'm building a daily driver/ expedition rig that can tow some small trailers for my wife so I can quit DD'ing my XJ and drive the car
    specs now:
    94' 5.2l V8 ZJ Laredo
    3.73 gears
    249 t-case
    ABS
    front LP 30 w/ stupid cv shafts
    rear LD d35 w/ drums
    30" tires
    I have some 2" pucks for the front and I'll likely throw some stock XJ coils in the rear to level it out.
    OR
    I have a line on a 3" Skyjacker kit
    I'll likely keep the 3.73 gears and step up to 31-32"s when I find a cheap set.
    I hate d35's, even with discs I have no confidence in even DD'ing that axle with a v8 in front of it.
    An 8.8 seems like the logical swap: stronger, same lug pattern, 3.73 gears, discs, etc...
    My questions are these:
    1.) Newbie question: I assume I'll be ok with stock trackbars, control arms and no t-case drop with a 2" lift?
    2.) What's the story on the 249?
    Crap? OK for nearly stock?
    (Again this is for my wife and keeping the option for AWD would be a plus)
    Should I ditch it and get a 242?
    if I swap in an 8.8,
    3A.) Is the ABS worth keeping?
    (remember this is Utah... it snows a lot, I've never had need for it myself but I am not my wife)
    3B.) And if so what are my options on keeping ABS if I swap in a Ford 8.8?
    I read all of these threads
    http://www.mallcrawlin.com/forum/sea...earchid=112059
    and this is the most I could find on the matter
    Quote Originally Posted by Mtn WJ View Post
    8/29/05 Since the ZJ is really a 3 channel ABS system you have two options for ABS.
    The ABS tone ring on the 8.8 is on the ring gear and has 108 teeth. The ZJ D35 has tone rings on both axle shafts just inside the hub. To use the explorer tone ring you will need to wire both sensors to the Ford Sensor and file every other tooth off of the Ford tone ring.
    The other idea is what Tom Z came up with. In my opinion the best one. You will need to file the very outer edge of the 8.8 housing to be flush with the seal. Then have the center of the ZJ tone rings machined to match the diameter of the 8.8 axle and have it pressed on the shaft. Keep in mind the tone ring is concave and you will need to have the concave portion pointed towards the differential to allow the most clearance for the ring to fit. Then drill a hole into the backing plate to mount the sensors.
    I suggest getting an 8.8 with discs on it already. I have seen 8.8's with discs range from 350-600 bucks depending on number of miles and where you buy it.
    4.) Will this work? has anyone done it with decent results?
  2. #2 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    I'm going to try to keep a tab on costs
    now for the pics:
    This is my third Cherokee
    Here's your generic, run of the mill, stock, Grand
    I'm pretty stoked on the V8
    Grabbed a new battery for her (warranty) $19.89
    And got a new front fender $50
    yanked the front axle to see what's up
    This isn't right
    remnants of a front bumpstop
    new one was $free$
    one of these things is not like the other...
    new one was $free$
    hmm that's bad
    time to polish the turdy on the cheap...
    bent
    chopped off
    Fixed (rugged ridge replacement $52/two)
    Homemade LCA skids ($free$)
    (American muscle needs some diamond plate )
  3. #3 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    well I found what I wanted
    http://www.mallcrawlin.com/forum/sho...8.8+abs&page=3
    Quote Originally Posted by DJJordache View Post
    11/8/06
    hey guys I got something more to add you can keep ABS with the 8.8!
    the Jeep system is 4 sensor but is still 3 hydraulic (front L&R and ONE rear)
    I have done it myself on my brothers 90XJ with a 8.8 and the ABS does still work and will do it again on my ZJ. I was going to go the route of the tone rings on each wheel (like Z did) but that is a pain and costly once you get bushings for the 8.8 shafts since the OD area on the 8.8 shafts is smaller in that spot than the d35.
    how I KEPT the ABS working on his XJ and will do the same on my ZJ:
    my ZJ tone rings are 54 tooth per side and the 8.8 has 108 teeth on the ring gear 54x2=108!
    his 90 XJ tone rings are 51 tooth but we decided to try it this way anyway. and later found out that the sensor does not count the teeth but just either sees a tooth or not.
    I took the angle grinder and ground down EVERY OTHER TOOTH on the 8.8 ring gear tone ring making it 54 teeth.
    We then wired both the Jeep rear sensors together left and right reds together and the ford sensor red all together and then if I remember correctly the left and right Jeep wires were yellow and wire those to the other ford sensor wire.
    finished the install and bleed the brakes, then took it for a spin. the ABS light came on at startup like usual and then went off like usual! and didnt come back on as if there was a problem. I then slammed on the brakes and YES the ABS was STILL WORKING without the ABS light comming on! and it has worked perfectly since we finished the install 2 weeks ago and the 8.8 with disks is a real nice upgrade in braking. The 8.8 was installed b/c with his stroker it blew up the D35 (broken spider gears, chewed ring and pinion, bent the cross-shaft and more)
    as far as I know I'm the first to be able to CONFIRM that this way works for sure. at least it did on his Bendix ABS brake system. I will later do this again on my ZJ when I find the right 8.8 with 4.10's in the yards.
    I can't wait to get it running in my ZJ but I have not found a 8.8 with 4.10's in the cheap yards near me where I can get it COMPLETE for about $100 in great shape too. I figure since I'm doing the work myself I might be able to pull off the whole swap under $300 for sure, but it's the little things that can add up quick.....
    here is a SUPER TECHNICAL wiring diagram I just made up for those that like pictures=)
    Keep in mind I also ground off every other tooth on the 8.8 tone ring to equal 54 teeth. And this for sure works on a 90 XJ ABS system, and will test is out on my ZJ hopefully soon
    2/11/07
    ok another bump since I got my 8.8 in yesterday but I didn't have much time to test it out since with my luck the one I got had a bad pinion bearing that is making a ton of noise and since it is sunday the ford dealer is not open so I can get another crush sleeve...... but anyways!
    I did it again and the ABS does still work on my ZJ and since pics are worth 1000 words check these out:
    SUPER TECHNICAL DIAGRAM V2.0
    and here are some pics of how to cut the tone ring to make it 54 teeth:
    The braking upgrade alone was sweet! and I did not even mod the prop valve and the braking is much much better than stock.
    now if I can just fix this stupid pinion bearing vib I'll be all good and I am looking forward to being able to use the 4wd
    hmmm now I need some D60's
  4. #4 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    more 30 polishing
    LCA skid, and knuckle gusset
    LCA skid, boxed ps uca mount, knuckle gusset, and welded a big washer on the notorious trackbar bracket mount
  5. #5 Re: Stock Rock'her
    Dodge
    Being a professional turd polisher myself, might I suggest you polish up some new CVs? Better yet start scrounging for some u-joint ones, lol. Looking good though.
    I have a year round cougar permit. Cougars are always in season.
    '93/6"-Custom 3link & Tri-4link Long Arm/4.6L Stroker/AW4/np231/HP30/D44/Detrioted-4.88s/35s/murdered out wood grain playa...
  6. #6 Re: Stock Rock'her
    Senior Member grandmaster's Avatar
    Utah
    I did my 8.8 swap a few months back and made the 8.8 work with ABS also, just use that diagram and its pretty self explanitory. P.S be careful when your cutting the jacket insulation off the stock abs, I managed to give myself a pretty good slice
  7. #7 Re: Stock Rock'her
    Senior Member Spr-T-23's Avatar
    Oct 2008
    Imlay City, Michigan
    i hate my abs, Alota Bull Shit, seems to kick in right when i dont want it to. Michigan roads suck so its quite offten, hit a rythem section when you are tring to stop and almost go through the intersection
    96 ZJ, Black, 5.2, Auto, 242 Swap, D30 D44a, 3.5 inch lift and 2 inch poly boost 5.5 inches total lift, 33/12.5/15 BFG MTs on Chrome steelies
  8. #8 Re: Stock Rock'her
    Member zjrog's Avatar
    Jan 2007
    Tooele
    Hey Stratton... You've been holding out on us after the teasers.
    Nice find...
    I think you'll be happy with it, ditch the CV axles for U joint ones, and swap that 249 out for a 242.
    I'm thinking when I do my control arms to make some skids too for the lowers. (Now that the yella heep is out of my hair...)
    1995 ZJ Laredo 4x4 Upcountry package
    1990 XJ Special PIA edition
    1990 Ford Ranger 4x4 2.3
    2002 Ford Supercrew 4x2 5.4
    2003 Dodge Neon SE "Half-a-Hemi"
  9. #9 Re: Stock Rock'her
    SWEET a newb that knows how to use the search!
    it is easy enough to keep the ABS so go ahead and do it and you can throw a switch on there to turn it off when you want to.
  10. #10 Re: Stock Rock'her
    Utah
    If your worried about the abs cant you just unhook it on the axle side? Or pull the fuse?
  11. #11 Re: Stock Rock'her
    Member Zombie's Avatar
    Salt Lake City
    Quote Originally Posted by Gravesdigger View Post
    I've got a set of 32x11.5x15 BFG ATs with about 5k on the runners, and a spare worthy spare, mounted on five aluminum five star wheels for sale.
    the smaller tire in this pic:
    I'm pretty much local to you, and I can probably meet your definition of cheap. PM me if interested.
    "Dood, you were a vampire driving a K5 Blazer. And that's the LEAST weird part of the entire story."
    -J B
  12. #12 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    Nothing really to report, I got the front axle back under it and tires back on last night hoping to drive it, but three stupid things foiled my plans...
    1.) discovered it has one broken shock that wont fully extend.
    2.) I also built a little cheapo diff cover armor
    but........ all my RTV is dried up...
    3.) Had my first run in with the factory Alarm...
    http://www.mallcrawlin.com/forum/showthread.php?t=17888
    Hopefully I can sort those 3 things out, give it a driveway alignment and drive it tonight.
    Quote Originally Posted by zjrog View Post
    That's 'cause that board is just for chit chat and....
    Scott is a turd burglar
    Nice find...
    Thanks guys
    I have my eyes peeled for some ABS u-joint shafts at the junkyards, I didn't see any last week
  13. #13 Re: Stock Rock'her
    all ABS D30 shafts have the larger 297X ujoints vs the nonabs/older 260X. Be careful that some 89-90 XJ D30's have a real high number of teeth on their ABS tone rings and are different from the 54 tooth one you would need
  14. #14 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    well I got everything sorted out this morning and drove it to work!
    super excited because I had only driven it a block before I bought it.
    I'm loving the V8 power, great seats! overhead console and auto headlights are pretty cool. It's going to take me a few days to figure out all the gadgets but I'm loving it.
    the steering is a little heavier than a part time case because of the 249 but way better than my XJ on 35's lol
    Thanks DJ, I'll keeping my eye out at the JY's for u-joint abs shafts, looked at 30+ XJ's and ZJ's last week and nada...
  15. #15 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    wife is now dd'ing it. She loves it.
    I'll get some shots of the new fender I put on over the weekend.
    I also rewired the Alternator with some lower gauge (bigger) wire.
    easiest alternator removal evar!
    Changed the oil.
    I need to figure out why the hood latch won't stay shut.
    and bend the dust shields so they don't touch the rotors.
    realign it again. And change all of the fluids.
    I also picked up roof rack cross beams and a set of leather seats from a later model limited that I'll install when I have a chance.
  16. #16 Re: Stock Rock'her
    Senior Member 2jeepsforus's Avatar
    Sep 2005
    Smethport, PA
    Ditch the dust shields entirely. If you do the slightest amount of mud or clay those things get packed full.
    1998 5.9, 5.5" Front/ 4.5" Rear (RE), 33/12.50's Trxus MT's, ARB Bumper w/Warn 9500HS, 231HD...SOLD...Stupid Divorce!!
    Quote Originally Posted by canadian_driver View Post
    start giving teachers guns... or tazers.... or clubs or just a 2x4 with a nail in it
  17. #17 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    new fender
    still need to reattach the inner fender
    Quote Originally Posted by 2jeepsforus View Post
    Utah: we're not down with the mud
  18. #18 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    Towing the new project home, guess what it is?
  19. #19 Re: Stock Rock'her
    Jan 2007
    Tooele
    That is a heavy trailer...
  20. #20 Re: Stock Rock'her
    Sep 2008
    wherever I lay my head
    Uhm, UT Route 24? Near Hanksville?
  21. #21 Re: Stock Rock'her
    Oct 2008
    Tennessee
    VW???
  22. #22 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    Quote Originally Posted by CSR View Post
    VW???
    yup
  23. #23 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    Yup,
    also that was with the 2" boost in front and no lift on the rear.
    ZJ is pretty much done, survived a cross country trip full of stuff so unless I feel like buggying it that's all folks
  24. #24 Re: Stock Rock'her
    May 2006
    York, PA
    [quote=Gravesdigger;220859]I'm loving the V8 power, great seats! overhead console and auto headlights are pretty cool. It's going to take me a few days to figure out all the gadgets but I'm loving it.
    quote]
    all that stuff is nice until it all goes to crap lol then its a huge headache chasing electrical wires everywhere .. if you werent bald before you will be now.
    "Say fuck you to Mother Nature, and kick her in the face! "
    94 Limited- 4.5" ghetto lift, Ghetto 33x12.50 Mud Kings, Ghetto wheels, Crappy stickers, some dents, custom front bumper(too be mounted), Kevins rad. support.
    Looking for 1980s VW Rabbit truck
  25. #25 Re: Stock Rock'her
    Aug 2007
    SLC, UT
    Oh so I never updated this build... the girl I built this for is now my exwife (2 years ago)
    the trip full of stuff... was her stuff she took with her... in the ZJ.
    I don't miss her at all... but man I miss that Jeep
