Thread: Project Christine (formally Mini Maxx)
Page 5 of 19 FirstFirst 123456789101112131415 ... LastLast
Results 101 to 125 of 455
  1. #101 Re: Project: Mini Maxx
    Senior Member Sudz's Avatar
    Pennsy
    Made in China
  2. #102 Re: Project: Mini Maxx
    Member floridaZJ's Avatar
    Aug 2007
    Clemson, from FL
    Quote Originally Posted by Jeeperoni91 View Post
    very little lube left in there, but they said it looked like the bolts backed out of the carrier and theres about 2-3 loose and 3 or 4 that fell out. that picture is of it not being messed with thats what i got to the shop to find my rearend looking like.
    and i drive hard on the street, easy on the trails. when it broke i punched it to the floor and the jeep raised up like it does in acceleration and "CRACK" and the jeep imediately went back down and no more power to the wheels. i could feel it when the gears snapped.
    It's possible that when the last person installed the gears they didn't clean the gear oil off of the bolts before applying the thread lock...
    Quote:
    Originally Posted by BigDaveZJ
    It's the midget version of Tommy's ZJ!
  3. #103 Re: Project: Mini Maxx
    SL,UT
    Quote Originally Posted by floridaZJ View Post
    That's why you should ALWAYS use NEW bolts when bolting the ring gear to the carrier.
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  4. #104 Re: Project: Mini Maxx
    Raleigh, North Carolina, United States
    gears were set up by someone cam knows....who went out of business.
    so who knows what happened, all i know is the bolts came out and i broke the ARB in 2 pieces.
    97 V8 zj.
    35"KM2s.aussies,4.88s,full chromos,1 ton hi steer in the 44/8.8.KOR/Clayton longarms.
    http://www.mallcrawlin.com/forum//sh...ad.php?t=17603
    03 Cobra with horsepowers
  5. #105 Re: Project: Mini Maxx
    Senior Member dangerousdave's Avatar
    charlotte
    sucks about the arb. Its been wheeled hard though.
    95 zj, KOR 7" long arm kit, lockrights front and rear, 285/75/16 (32.9x10.3) on rock crawler 16x8x4.5bs, kevins track bar with a home brew conversion, K&N FIPK, and Rubicon Express gen II discos.
    Ready for install... home brew sliders
    http://www.mallcrawlin.com/forum/sho...hlight=sliders
    Dr. Mambo
    http://www.mallcrawlin.com/forum/sho...ighlight=mambo
  6. #106 Re: Project: Mini Maxx
    jeep will be done tomorrow
    tubes welded more
    bumpstops that came out anyways removed since i have limit straps
    driver rear brakeline re-done ( i pinched it up bad )
    open carrier put in
    aussie put in
    yukon 4.88s put in
    royal purple and lube lockers put in the 44 and 8.8
    i can't wait to drive it again, been out since the tuesday before the election.
    97 V8 zj.
  7. #107 Re: Project: Mini Maxx
    Anyone know if the kor front tracbar has to use their bushings or if I could get jks bushings to replace mine?
    97 V8 zj.
  8. #108 Re: Project: Mini Maxx
    Senior Member canadian_driver's Avatar
    Canada, somewhere
    you can use JKS bushings, or energy suspesion universal bushings
    This person should be taken as seriously as a heart attack while piloting a zeppelin over a bacon factory, which is the most serious of heart attacks, because if that zeppelin crashes into that bacon factory all of us will be without bacon and that simply will not do.
  9. #109 Re: Project: Mini Maxx
    turns out my 8.8 is bent, which caused everything to happen that did.
    gotta take it to charlotte to get andy from what used to be carolina rockshop, now he works for fabfours, to straighten it so i can get the shaft back in on the pass side.
    FMJ!
    ^^f-my-jeep
    97 V8 zj.
  10. #110 Re: Project: Mini Maxx
    Dec 2005
    Central Mass.
    Wouldnt the 100 bucks (roughly) for a new 8.8 housing be easier then getting it straightened?
  11. #111 Re: Project: Mini Maxx
    Quote Originally Posted by Derek33 View Post
    grinding, getting new link mounts, new truss, new triangulated shock tabs for the limit straps, welded them on, painting it....done in a week if i'm REALLY lucky and don't homework and everything were to happen like i'd want it to (which seems to not happen when it comes to my jeep)
    too much time, and more money than getting it straightened for about $150 and 2 hours.
    jeeps been down for like a month and a half, and its my DD. don't have time to build another 8.8 cause i need the jeep back on the road again, driving a 4 cyl 5 speed tj gets old quick too.
    97 V8 zj.
  12. #112 Re: Project: Mini Maxx
    Dec 2005
    Central Mass.
    I completely forgot about the welding up of the brackets and such. I gotcha now.
  13. #113 Re: Project: Mini Maxx
    Oh if there was a a bolt in 8.8 I'd already have it on the way in
    97 V8 zj.
  14. #114 Re: Project: Mini Maxx
    turns out derek's idea is coming through because of some luck, maybe things will turn around on this stupid thing...knock on wood...
    a guy in my jeep club was going to build a 44/8.8 and put it under his xj this winter, but decided(today) he might as well go 1 tons on it and save doing the work twice...so he's selling the 44/8.8....so theres my new 8.8 housing, already stripped really really every single spot has been checked on it, tons of time in it already so it's in great shape. all i have to do now is weld brackets onto that bitch and put all the pricey stuff back inside it, but not until next weekend so yet another week goes by that my DD is rear-axle-less.
    97 V8 zj.
  15. #115 Re: Project: Mini Maxx
    Dec 2005
    Central Mass.
    Sucks when you're rig is your DD don't it.
    I wanted to get some wheeling in while i was home from school for thanksgiving, but if i broke anything I'd have no way of getting back to school. Can't take the chance.
  16. #116 Re: Project: Mini Maxx
    http://www.youtube.com/watch?v=s2es2qyyOEA
    http://www.youtube.com/watch?v=9ymyM...eature=channel
    theres some more footage i found from a member of my local club on youtube from our last uwharrie trip. little white xj is the guy that made the videos, therefore he's in the videos the most.
    97 V8 zj.
  17. #117 Re: Project: Mini Maxx
    new 8.8 is welded all up and in the jeep, gears are getting set up tomorrow, shafts in brakes on all that jazz....and jeep will be back in action after 7 weeks on the disabled list
    97 V8 zj.
  18. #118 Re: Project: Mini Maxx
    got my jeep back and realized how much i don't like DD'ing it.
    no swaybars, no alignment, bad bushing in the front tracbar...eek.
    glad i have it back though.
    97 V8 zj.
  19. #119 Re: Project: Mini Maxx
    Jan 2006
    Raleigh, NC
    So get some endlinks and setup a sway bar. It'd make a ton of difference.
  20. #120 Re: Project: Mini Maxx
    Quote Originally Posted by spykosshow View Post
    xmas money is going towards some discos, bushings and the Aero
    97 V8 zj.
  21. #121 Re: Project: Mini Maxx
    rained all day and i have a wet passenger side husky liner. wtf? anybody know a ghetto fix to a leaky windsheild seal?
    97 V8 zj.
  22. #122 Re: Project: Mini Maxx
    Jan 2005
    Renton, WA
    Loctite's "gasket maker" in a pressure tube. You'll never use anything diffrent for anything. Works awsome on diff covers/tranny pans/oil pans/ full float shaft. You get my point
    8" RK/ Acos lift, rancho rs9000x shocks 32" extended, Claytons Longarms, with 38X12.5 TSLs, Custom Rear bumper, custom front bumper, Waggy D44 front 4.56's and Detroit locker with warn premium hubs and yukon alloys and 8 lug conversion, D70 out back with 4.56's and Welded, 242 transfer case, 1 Ton steering setup. Rhino lined interior, olive drab exterior, and PSC 1.75" hydro assist ram.
  23. #123 Re: Project: Mini Maxx
    Got xbox live, gamertag is grandjeeep97, with 3 e's. Hit me up on cod5 or NCAA fb 09
    97 V8 zj.
  24. #124 Re: Project: Mini Maxx
    engine is locked up. time for a new jeep, 5.9 perhaps?
    97 V8 zj.
  25. #125 Re: Project: Mini Maxx
    scratch that, going to get a re-manufactured engine in there instead. could i put a remanufactured 5.9 in there direct swap where the 5.2 was?
    97 V8 zj.
