The Polar Bear - NP241 Upgrade - Page 9
Thread: The Polar Bear - NP241 Upgrade
Page 9 of 30 FirstFirst 12345678910111213141516171819 ... LastLast
Results 201 to 225 of 737
  1. #201 Re: The Polar Bear - 5.3L Chevy Install
    Feb 2008
    Dublin, Ohio, United States
    how did i miss this. that is an amazing build!
  2. #202 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Quote Originally Posted by blackzj52 View Post
    Thanks bud!
    Any ideas for that passenger side manifold? Any other hangups at this point?
    I'm trying to find a reasonably priced set of LS2 manifolds like these, hopefully they will work. Baring that there are a few sets of CARB certified shorty headers I have found that I can cut and modify if I need; like to change the angle of the outlet flange but I'm still hoping for a cheaper solution. Other than that I think I have solved all other major problems, now it's just all the little stuff like plumbing trans cooling lines, power steering lines, coolant, etc...
    I collect Jeeps.
    The Polar Bear Build on Mall Crawlin
    The Polar Bear Detailed Build
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience."
  3. #203 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Alright I'm continuing to plug along while I search for a reasonably priced set of LS2 manifolds. I got a ton of wiring done going to the interior for the remote start, gauge cluster lights (check engine & cruise control) and OBDII. I also mounted the drive by wire pedal and got the brake pedal back in.
    Now this next part is in no way hardcore but I figured I'd put it up here anyway. The leather on the steering wheel has been cracked and flaking shit since I bought the rig. I looked into having it rewrapped but long story short did it myself.
    Before:
    After:
    For those interested in how I did it (I'm sure I'm not the only one with a shitty ZJ steering wheel) I did a write up here.
    Alright flame on
    I collect Jeeps.
  4. #204 Re: The Polar Bear - 5.3L Chevy Install
    Feb 2008
    Great work! My wheel is starting to peel as well (not nearly as bad as yours was) and I've been wanting to do something about it. Now I know what to do. Thanks a ton for that writeup
  5. #205 Re: The Polar Bear - 5.3L Chevy Install
    Jan 2008
    Wichita, KS
    Man, I give you props for the dedication to stitch all that!
    looks great
  6. #206 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Thanks a lot guys
    I collect Jeeps.
  7. #207 Re: The Polar Bear - 5.3L Chevy Install
    Senior Member dp96zj's Avatar
    Texas
    ehhhh, it looks like shit
    just kidding man, looks great!
  8. #208 Re: The Polar Bear - 5.3L Chevy Install
    Oct 2009
    Florida
    Props to you for having that much patience. I just dont think I could do it.
    2004 Ford Lightning
  9. #209 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    I certainly wouldn't want to make a career out of it but it wasn't that bad. I spread it out over two nights while watching TV and having a few drinks. Actually I had enough leftover afterward that I redid the shift lever and parking brake levers too.
    I collect Jeeps.
  10. #210 Re: The Polar Bear - 5.3L Chevy Install
    dude, i'm blown away by how well that came out. I've hand-sewn two covers and neither looked that good. How'd you keep the stitching so tight? Did you buy a special kind of leather? UV treated or anything?
  11. #211 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Quote Originally Posted by paulkeith View Post
    To get the leather so tight I cut it a little smaller and just stretched it using the stitching. I'm not sure if the leather is UV treated. The guy I bought it from does it for a living, he has a motorcycle almost completely skinned in leather that looks bad ass. This is what he recommended. I do know it was on the thinner more flexible side as far as leather goes that helped a ton. Honestly I've never worked with leather before in my life.
    I collect Jeeps.
  12. #212 Re: The Polar Bear - 5.3L Chevy Install
    Apr 2008
    Tn
    Nice job on the wheel! I may have to use that as motivation to one day recover my Dodge steering wheel.
  13. #213 Re: The Polar Bear - 5.3L Chevy Install
    Member leeanderthal's Avatar
    Jul 2008
    Benton Harbor, Michigan, United States
    You made it look easy. How did you stitch the three pieces together? Sewing machine or by hand?
  14. #214 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Quote Originally Posted by leeanderthal View Post
    Haha thanks. I just hand stitched it, I don't even know anyone with a sewing machine.
    I collect Jeeps.
  15. #215 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Got the SwayLoc installed today, pretty happy with how it's turning out. I used a SwayLoc intended for a TJ because from my understanding they have the longest arms. I want long arms so that at full droop I don't accidentally invert the sway bar (I've done it before)
    This part was very much inspired by GoldenSD's SwayLoc install, so credit where credit is due. Here is the combination sway bar bracket and radiator support. Amazingly this thing only weights 5 lbs more than the original radiator support and it is way beefier.
    Here is the driver side at ride height, I love how the flash brings out every damn spot of rust, I can't wait to paint & powder coat this stuff.
    And the passenger side.
    Here is full bump, it touches the coil over hoop barely, so I'll do a little clearancing tomorrow.
    And here is full droop, you can see why I wanted the longer arms with these 14" coil overs. Even here I'm a little nervous about the angle between the arm and connecting rod, I might make my own custom length ones.
    I collect Jeeps.
  16. #216 Re: The Polar Bear - 5.3L Chevy Install
    Texas
    Do you think it would help any to throw a gusset between those two plates on the trackbar mount? I'm sure you worked calculations and stuff, but it just looks like it could be a little stronger to me. I may be wrong, but that's just my observation.
    Love the build, can't wait to see it moving!
  17. #217 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Quote Originally Posted by dp96zj View Post
    I'm going to add a cross piece, just haven't got to it yet.
    You and me both! Doubly so after seeing ATLZJ's buggy driving with his new chevy motor.
    I collect Jeeps.
  18. #218 Re: The Polar Bear - 5.3L Chevy Install
    Quote Originally Posted by downtowncb View Post
    Haha, mallcrawlin GM Gen III club... now awaiting new members
  19. #219 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Found some Corvette headers finally, they are on the way!
    Measured for the limit straps and picked some up. It is handy having Poly Performance two miles away.
    This contraption is going where I had intended to put the second battery, looks like it will be going in the back instead. This is a rack that holds the compressors for the lockers on the bottom, the Chevy ECU in the middle and will hold the fuse & relay panel & iPhone controller on top. That cluster of connectors on the right will all be coming out of the fuse box (totaling 56 wires) , it's a lot to keep track of haha.
    I collect Jeeps.
  20. #220 Re: The Polar Bear - 5.3L Chevy Install
    Aug 2009
    Alberta, Canada
    Sweet build! I'll start a build thread when my 5.3l starts going into my WJ.
  21. #221 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    I continue to make progress but most of it isn’t photo worthy. I’m still waiting for the headers to get here.
    I’ve wanted to have HID fog lights for a long time but they are EXPENSIVE, so I pieced my own together. I have about $125 into each, which is a lot cheaper than most setups.
    I used 55W 5000K HID bulbs and Hella 4000 housings. The Hellas come with H1 bulbs so I just order the HID setup with the same.
    I had to do a little modification to get them in there but nothing major. I used a stepper bit to drill a hole in the back of the housing and the stand large enough to fit the bulb connectors through.
    I used a grommet on the back to protect the wires and keep stuff out.
    I don’t have a real world shot yet because they aren’t on the Jeep but here is a garage door shot. I am VERY happy with how bright these puppies are and the quality of light.
    I collect Jeeps.
  22. #222 Re: The Polar Bear - 5.3L Chevy Install
    Beaumont, Texas
    Dang man this stuff is way cool, Is your last name mcgiever?
  23. #223 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Quote Originally Posted by it usually runs fine View Post
    Haha I grew up watching MacGyver and last Christmas my parents gave me all the seasons on DVD, definitely one of my heroes
    I collect Jeeps.
  24. #224 Re: The Polar Bear - 5.3L Chevy Install
    Oct 2009
    Florida
    Cool idea on the hid upgrade. Added to must do to Jeep list. Thanks alot...LOL
    2004 Ford Lightning
  25. #225 Re: The Polar Bear - 5.3L Chevy Install
    Seattle, WA
    Hey, I showed it can be done on a budget!
    Got the HIDs from http://www.ddmtuning.com for ~40 shipped (I remember when these things cost like $400). Got the Hella 4000s from http://www.adv4x4.com/hera40coblla.html for ~210 shipped.
    I collect Jeeps.
Tags for this Thread
View Tag Cloud
